Pyramid Power
I picked up a pair of Pyramid PW1077X 10" subs the other day. Just gave $20 for the pair, box included. I know these are crap from the get go. Any way, I have looked around the web for some theil-small specs for these paper weights but cant find any. I cant seem to locate a website for Pyramid either. Does anyone know where I can locate some specs for these subs? I plan on playing with them for a while just to see what they can stand (power wise that is). Any help at all would be appreciated
Thanks, Cujo
Ok well that's interesting. I seem to recall a little while ago doing a test and not having the same results from someone even closer than the short drive from Ontario.
EDIT: I should have said no quotes, sorry for the confusion.
EDIT 2: We should mention that the short drive from Vancouver (BC) to Toronto (Ontario) is a mere 4412 km.
being halfway between you guys but a ways south, I get:
Soundreproduction.com
diyAudio Forums Archive - Loudspeakers
Loudspeakers - Audioholics Home Theater Forums
using quotes I get:
Problem or now with loudspeaker's? - Forums at ModMyiFone.com ...
diyAudio Forums Archive - "fisss" on the 6C33C-pp
diyAudio Forums Archive - First time caller, long time listener...
the third a "subhit" of the second
