Pyle PLA4180
Ok all op-amps are NJM4558LD I have the same voltages on all of them..
Pin 1:24.18
Pin 2:12.04
Pin 3:12.01
Pin 4:12.18
Pin 5:0.88
Pin 6:12.02
Pin 7:12.04
Pin 8:10.98
I replaced my batteries in my multimeter since they were getting low and this is what i have now on all op-amps
When measuring the voltage (unless otherwise instructed - for this amp), place the black probe on one of the non-bridging speaker terminals.
Are you sure that all of the op-amps had the same voltage on pin 5?
Are you sure that you have the pin numbering right? It appears that they're reversed.
