Hello everyone. I would like to have an input on which you think would be the best compression driver for a Pyle PH12s Constant directivity horn. The driver needs to get below 1000Hz (the lowest possible). The application is an Open Baffle 2 way design with an Open DRC from Mini DSP as a crossover/EQ and dual power amps.
The closest thing I have found in a budget is the Peavey RX22, which goes down to 500Hz on a 1" opening.
