For Sale Pyle Audio PP999 Hot Rod phono preamp
Things you have for sale.
Pyle Audio PP999 Ultra Low Noise Phono preamp. Hot Rod mods include upgrade power supply filter caps from cheap 47uF to Panasonic FC 220uf, (one per each voltage rail) removed cheap electrolytic input caps and replaced with Tantalum caps, removed cheap electrolytic output caps and replaced with 2uF Panasonic poly film/foil. Added IC socket so you can replace stock NE5532 with your choice high end audio opamp (both the LM4562 or the OPA2134 sound fantastic in this circuit). Even without the opamp swap, this sounds way better than it should with the mods...even better with opamp swap. 100% operational, no hum, no noise. This easily competes with preamps 2 to 3 times my asking price.
Original AC wall wart, box and packaging. Asking $75.00 obo
Shipping CONUS only.
