PWM 10 Amp constant current source 24-96V?
Posting this @ diyaudio, obviously many great minds reside here....
What circuit topology would you recommend for:....designing a SMPS/PWM based current source power supply to drive a 1ohm inductive load (motor field winding) from 24-96VDC at 10A, and the ability to vary current is a plus....
I did have a PWM circuit measuring the volt drop via feedback across a 0.055 ohm resistor in series with the load, and the resistor heat dissipation was very high, so I'm looking for other options..circuit worked very well for a while....also had peak starting current eventually burn the resistor and blow the MOSFET!
Also had an idea of using an inductor in series with the load, and measuring that, , maybe a sensor, or even just making a 96Vin/10Vout power supply instead (10V/1ohm=10A)
Ideas and comments welcome!!!
