Purpose of lining an enclosure?
Assuming a ported enslosure - what are the real reasons to line an enclosure?
a) To further reduce individual panel resonances
b) To absorb / reduce standing waves
c) To help absorb unwanted noise (speaker motor, particular frequencies (eg. 200Hz+ for a subwoofer etc...)
d) To keep the speaker warm 🙂
Have I got one of the above wrong? Any other reasons?
For a subwoofer - assuming lining "helps" in one or other of the above - does it matter what the material is? (thick felt, some sort of wool, dacron / polyester, egg crate foam???). I've read each of these has different absorption characteristics in different frequency bands but am a bit confused.
If I am going to line the box - I just want to know its worthwhile doing so (or why bother)... (like all those flash interconnect cables 😀 )
Thanks,
Dave.
Well standing waves should not be much of an issue for a subwoofer. The box is many times smaller than a single wave. Also traditional lining would not have much effect on the low frequency produced by a subwoofer anyway.
There is the benefit of enlarging the apparent volume by stuffing, especially in a closed box.
For a subwoofer the main issue is cabinet wall vibration. Standard lining does not have much effect on this. Some amount of mass is required along with damping to absorb this.
You should isolate the woofer from the cabinet. The main cause of cabinet wall vibration is from the physical contact of the woofer basket.
Thickening the walls also reduce the vibration and will eliminate it if the walls are thick enough. Which is why some go to extreme measures in building boxes, ie ... concrete, lead, bricks... Using a sonotube is a real neat way to bypass a lot of these issues since a tube will not expand under pressure and does not have a lot of the disadvantages of flat walls.
You should brace the box extremely well. I think it is best if the braces are single pieces with cutouts and unbroken sections connecting the center of opposing walls.
Bracing reduces cabinet wall vibration but it will not eliminate it. To do this you need to damp the vibration. To do this you need to add some damping and some mass. Some coat the inner surface with rubber or tar, or sand mixed in with some sticky goo.
My favorite method is to provide a constrained damping layer. This is a rigid mass, that is attached by a flexible adhesive. Vibration of the outerwall is transfered toward the rigid mass, and absorbed by the friction between the layers. I sometimes attach plates of hardboard, with about 1/16" flexible chaulk.
For my next subwoofer, I plan on trying a box within a box approach. This is a braced box, with the subwoofer driver attached, contained within another box, with a thin flexible layer between them.
James
James,
I agree with most of what you’ve said. I also like your arrays on your web site, very nice. They remind me of the old Infinitys.
Although I do have a different opinion on a couple of the point you made. A woofer (particularly a ported sub-woofer) can generate quite a lot harmonic distortion in the lowest octave. The third or forth harmonic can create standing waves within the box that will be transmitted through the port if they are not damped. This is one of the primary reasons for lining a ported enclosure.
Any direct radiating speaker (woofer or not) should be rigidly mounted to the baffle. Decoupling the speaker from the baffle sets up another resonance (most likely in the audible range) that you now have no control over. The baffles on my subs are nearly 2” thick with layers of plywood and MDF. The woofer is bolted directly to the baffle with only a thin gasket to form a seal. In this way the speaker frame is fixed to the 90lb. enclosure so the only thing vibrating is the cone.
Rodd Yamashita
I am not sure we totally disagree here. The "thin gasket" would be considered decoupling to me. Perhaps not completely, and perhaps not by your intention. I certainly don't advocate loosely mounting a driver.
I find this an interesting point one that I am not familiar with. If so it is an issue frequently ignored in subwoofer design (which doesn't mean it isn't true).
I would like to understand more about this.
I'd like to add something to what Rodd said.
Don't forget that--unless you're using some sort of brick wall filter--you're still going to get some information above the cutoff frequency for the crossover. If the cabinet has a resonance, it won't take much energy to get it going.
Furthermore, regardless of the crossover point and driver energy, you're going to be taking in frequencies from the main speakers, even if they're all the way across the room. This is easy enough to demonstrate. Unhook the sub, put a mic in the cabinet (easiest if it's a ported design), and play the main speakers. If you listen to the output from the mic via headphones, you'll hear some pretty interesting things going on inside the cabinet. If your headphones are open style and the music from the mains is too much, then record the mic signal on a cassette deck and play it back afterwards.
Incidentally, this is a mild argument against using reflex cabinets. Sealed cabinets and transmission lines are less prone to this kind of thing.
Another source of higher frequency information is cone breakup. This will vary quite a bit with driver design.
All in all, there are more high frequency things going on in subs than meet the eye.
Grey
Thanks Gray, I totally overlooked the idea of the low-pass rolloff rate. Furthermore, with sub-woofers you want a relatively steep high-pass rolloff rate if you don’t want to contaminate the mid-bass output with the sub-woofer output particularly if your xover point is approaching 100Hz or higher. I learned first hand that this can just destroy your imaging. 3dr or 4th order slopes are called for here and 12db/oct cutoff may be too shallow.
While Gray was replying to this thread, I did find a great reference site with a number of AES presentations on the large signal performance of direct radiating loudspeakers. There is a lot of discussion about excursion related distortion products.
http://www.klippel.de/pubs/default.asp
WRT my speaker gasket, I use a thin, soft, closed-cell foam that compresses to virtually nothing. So for all practical purposes, the speaker is rigidly mounted to the baffle.
Rodd Yamashita
6db/slope crossover ok?
What you said about crossover slope worries me. I just realised the plate amp I intent to by only has a 6dB slope! - which doesn't seem steep enough to me?
I have not measured my mains - so can't say what a good integration slope would be (I can't control the main's xover since my receiver is an old 2 channel and I'm not about to pry into my mains - the drivers are not screwed into the cabinet in the conventional way)
Should I be looking at an 18dB slope (or greater?) Can I achieve this by putting an inductor in series to the parallel DVC wiring to the Adire Shiva driver from the amp? (or would the size of the inductor be prohibitively large at 200Hz or less).
I might need to read up on active xovers.... 🙂
Thanks for your replies,
David.
Old (well, 10 year old) stuff - but still works as good as the day it was bought
- Denon 40 watt receiver - DRA-335R
- Wharfedale 505.2 bookshelf speakers - 1" aluminium dome, 6.5" polyprop woofer. 8 Ohm impedance, rated 100watts.
the wharfedales claim to use a "bayonet fixing" on the woofer, sealed enclosure - approx 10Litres. the woofer has 3 slots just past the butyl / rubber surround (which is an odd shape - its concave - probably to avoid suck back at excursion). Probably needs some proprietary tool to remove. A friend had his reconed / coiled when he burned his out 7 years ago (funnily enough the woofer crapped out before the tweeter - he only had a 60 watt receiver).
Bright sounding setup - woofer sounds a bit nasal as well (tweeter probably crossed over too high and woofer beign asked to do a bit too much - maybe needs a contour or notch filter network). I'd like to tone them down a bit - should do some measuring. Probably could do with xover component upgrades
Anyway I'm lacking in the bass department - thought I'd start with a reasonable sub and work my way up through the system
Dave.
I lined my cabinets with a sound and temperature insulation that I first saw in an aviation supply and later found in Home Depot being sold as water heater blankets for $20 a 4' X 6' sheet. For more info check out my thread "Isobaric Subs" in the DIY forum at the www.audiokarma.org site. I have misplaced the packing label but the stuff is good at trapping sound, is light weight and less than $1/sq ft.
For internal bracing try the ash dowel used for hanging clothes on. Very strong and round is a good shape to cut through the center of a speaker box.
G'day Rodd,
Do you have connections on the rear of the receiver for "pre-amp out" and "amp in", connected with a jumper?
No sorry - she's a pretty simple receiver - only high level speaker outputs.... no pre-amp out or anything like that (that was an extra feature on the next model up 🙂
Hey - I just realised something. Can I use the tape "rec" (line out)? since the receiver has a tape monitor switch?
Only problem - volume won't vary - since it doesn't go through the preamp.
High level outputs it is then! Will I loose too much sound quality? (I suppose it depends on the quality of the electronics in the plateamp)
BTW - its a redgum RGsw2 (made in australia):
http://www.users.bigpond.net.au/redgumaudio/rgsw2.html
Dave.
I forgot to ask...
The plate amp (see the link above) only has a 6dB xover. I think this will be too shallow (as my mains will no doubt have a much steeper rolloff) - I'm afraid the system will "boom" - since I cannot modify the xover to the mains.
Any suggestions?
Thanks,
Dave
Dave,
I noticed that the Redgum has only line level inputs. If you have no pre-amp out, what were you planning on using for the inputs to the Redgum?
This is where you would apply your own active xover, but you must again be able to have access to your pre-amp out signal and receiver amp in connections.
You might want to start a new thread in the SS catagory asking how this might be accomplished inside your receiver.
I'll be watching
Rodd Yamashita
Thanks Rodd,
Redgum supply a high level plug in board to take the speaker outputs of the receiver - so no problem there.
I might start the new post as suggested. I want to investigate the shallow 6dB rolloff of the sub amplifier - which I will also do as new thread,
David.
standing waves (from THD or cutoff rate) are not going to be absorbed by the lining
, at least not significantly. The pressure max is at the walls, whereas the volecity max is at some point within the enclosure, depending on the order of the wave.
Damping material is not efficient for pressure, just for velocity. At the frequencies of concern, it would have to be many inches thick to have an effect.
To achieve this end, it should be placed close to the center of the box. I usually use two braces spaced several inches apart which have several large cutouts, cover the cutouts with 5 mm thick wood-felt (the stuff that is meant to go between the concrete floor and whatever surface, i.e. tiles, polished wood, carpet, is on top). Between the braces I stuff rock wool.
Capslock,
Are you saying only standing waves cause panel resonance? I thought every panel has some resonance frequency - its own fs if you will.
As such the purpose of bracing is to make each panel smaller - pushing that resonance up in the frequency spectrum - whereas the lining / batting on the walls is to absorb energy that would make it resonate in the first place?
eg - bracing is resonance prevention, damping and lining is resonance cure.
Dave.
