Hello I have just bought one of these s/h and it works fine except the display brightness seems a tad low to me. Does anyone here have one? does it seem dull to you? I know it has a 4 stage dimmer but there is not much difference between them...🙁
This one you mean,
http://www.diyaudio.com/forums/solid-state/96192-post-your-solid-state-pics-here-15.html#post1417430
Can't really say it seems dull at all tbh. It's not dazzling but I wouldn't want it to be.
It's well balanced and I use the mid setting. Have you cleaned the rear of the window and the display itself ? The brightness of the display is a "visual" match for the blue LED's at all settings if that makes any sense. Nobodys fitted incorrect bulbs at any time...
These are a great tuner by the way. Worth checking the later firmware is installed as it irons a few bugs out such as reversed L and R on SPDIF amongst other things,
DRX-70x series tuners - Downloads - PURE HelpCentre Helpdesk
Edit... you say there is not much difference between them. Do all the blue LED's alter in brightness correctly as you step through the dimmer values. They should...
I'm now fairly sure it is dimmer than it should be there is a VERY slight difference in brightness as the button is pressed. I've had a look inside and there is no obviously simple thing like a poor connection... anyone know what the voltage to the panel should be?
