I need to know wich are the types &/ qualities & where can buy at a reasonable price?
R-core transformers from vt4c.com.
Audio Catalog
Thank you, I know this web but can not see the R-Core or Z11 Laminated wit proper voltage & power required and don't want order a custom made because is very expensive, I search 240 or 260VAC & for filaments 8.5 or 9VAC.
I've used these in the past, mostly for prototyping. Does the job and not too pricey.
Valve Transformer VT342
Why 8.5V heaters? 6922 is a 6.3V heater unless you're planning on DC heater supply.
Thanks for the link, is the voltage used by Audionote....
