Hello,
I'm searching for KSC1845 and KSA992 pspice/ltspice simulation models, I've found them in ON Semi website, but they seems to be wrong, because simulation give strange results. Searching on the web (and on this forum) I've found that many users had the same problems.
I tried to build the models myself, but the datasheets don't seem complete enough to do it ... or yes?
I also read that they seem to be very similar to BC550C/560C except for the saturation region. If that so, can I use Bob Cordell's BC spice models changing the "BF" value and obtain the same results?
If I can't use that models, anyone have the correct KSxxxx models?
I have the following:
.MODEL 2SC1845E_kq npn IS=1.075431E-13 BF=600.7 NF=1 BR=13.565 NR=1 ISE=1.98107E-13 NE=2 ISC=1.8378E-11 NC=1.5 VAF=200 VAR=20.6691 IKF=55m Nk=0.66 IKR=0.0190546 RB=157 RBM=12.092 IRB=1.258925E-6 RE=1.5 RC=1 CJE=18p VJE=0.7300286 MJE=0.3619943 FC=0.5 CJC=4.525739E-12 VJC=0.5 MJC=0.3659045 XTB=1.7281 EG=1.1809 XTI=3 Tf=420p Itf=20m Xtf=1 Rco=250 gamma=2u Vo=500 Vceo=120 Icrating=50m mfg=NEC
.model KSC1845F_kq ako:2SC1845E_kq NPN Vceo=120 Icrating=50m mfg=Fairchild Bf=355 Ikf=300m Vaf=400 Ise=1000f Ibc=600f Rco=150 Gamma=10u Vo=9 Isc=22f
.MODEL 2SA992F_kq pnp (IS=5.7544E-14 BF=348.1 NF=1 BR=3.62 NR=0.95 ISE=5.7544E-15 NE=1.5 ISC=1.8378E-14 NC=1 VAF=50 VAR=16.68 IKF=0.298 IKR=0.0525 RB=140 RBM=16.084 IRB=1.4125E-3 RE=0.3 RC=100m CJE=13p VJE=0.855 MJE=0.4104 FC=0.5 CJC=8.9251E-12 VJC=0.5 MJC=0.3497 CJS=0 VJS=0.8 MJS=0.33 XTB=1.2849 EG=1.1603 XTI=3 XCJC=0.3062 Tf=420p Itf=5 Xtf=.5 Vceo=120 Icrating=50m mfg=NEC Rco=100 gamma=200n Vo=500)
.model KSA992F_kq ako:2SA992F_kq PNP Vceo=120 Icrating=50m mfg=Fairchild Bf=404 Vaf=110 Ikf=150m Ise=15f Isc=0.0010f Rco=70 Rc=0 Gamma=1500n Vo=100 Ibc=45f Is=75f
Sajti
Sajti
Sajti
Thank you, I'm testing them 🙂
