ok i read it on one of the diy sites but cant find it now but the problum im having is i did the vga mod for my psone lcd for a tv box and im geting double image on it and am not sure how to fix it anyone have an idea?
Double Image
You might check your fresnel lenses, I had he same problem when m light source warped my fresnel lenses, which caused my image to double a little bit, very disconcerting
i found the problom its because the sync is to high on the tv box for the psone lcd and theres no way to adjust it without useing resistors so i got an ohp projecten panel witch is much nicer and cheaper and 10" with 640-480 works great.
double image is MOSTLY due to grounding. make sure all your connections are solid and interference free.
yea but the psone wasnt wven in a box i tryed it just by opening the bottom of the lcd and hooking up the vga cable mod. its just that the tv box puts out 640-480 minimum res and the psone lcd is less then that so sence its not hooked up to a pc where i can use powerstrip to fix the sync it wont work.
