Hey Everybody
I have a PSOne screen and are in the process of making my Projector.
I only have the problem that it tends to overdue the Red's in scenes with a lot of red in them 🙂
Found a way to fix it: http://www.diyaudio.com/forums/showthread.php?s=&postid=400154&highlight=#post400154
But I am not the best at electronics so it doesn't make that much sense to me.
Is there somebody out there who has already done these things who could help me. (LOTS of pictures 🙂)
Have already tried this Brightness mod: http://www.extremetech.com/article2/0,1697,1765358,00.asp but that did no work for me... Didn't get any picture at all after doing it... Luckily I could desolder the piece of wire afterwards 🙂
/Daninino
/Daninino
Update!
Hey Got the Brightness mod to work just soldert in on in the correct place 🙂
But I still need to fix the Red Issue. Is there anybody who can help me. I live in Denmark and have NO idea what a potentiometer is.
/Daninino
/Daninino
A potentiometer is simply a variable resistor. They are very common products. Do you have radio shacks in denmark? Common items they could be found in would be an automotive headlight switch(with internal dimmer) a dimmer switch for around the house(many others i am sure but cant think of any) etc..
that helped a bit 😀
And no we don't have Radio Shacks, have to find the parts at special Electronic stores and I am not quite sure if there is one nearby
It is not as common to buy these sorts of things in Denmark I presumed... Wish I still was in school, then I could probably get one there :S Oh Well
/Daninino
that helped a bit 😀
/Daninino
