can someone help me on modding a psone for rca........
i just need to know when you strip the wire on the (video)rca it has two wires
do you have to twist the two wires together then solder them or do you just solder one
well u need both.
one is ground and one is the live one.
the one with the white coating is the most important but you still need the ground to get it to work.
