I'm working on a 5.1 Dolby Digital System and now I reach the point where I'm think about the power supply. I talked to a lot of guys and I've got a lot of different answers.
My problem is that I need a Trafo with 76V with 180Watt and 2A output per Chanel (of course for audio amplifier)
My question is if it's better to make one Trafo for each Chanel or one Trafo for all five chanels??
It would be easier for me to make it with one Trafo but I'm afraid that there will be to much interferences.
if maybe some of you had the same or similar problem please let me know which experience you made..
tanks wolfi
tanks wolfi
Are you quoting AC or DC volts/amps?
I am a believer in putting the amps beside the speakers. Using short speaker cables and long line level interconnects where required.
I also believe that multi-channel amps need a careful and thorough understanding of how the currents flow in the various interconnected circuits to avoid problem with audio quality. It is much easier to build a good sounding monoblock than a stereo on a shared transformer. Going to 6channel is even more complicated.
could you explain where this specification came from?Trafo with 76V with 180Watt and 2A output per Chanel
i need for one chanel 2x 30V power supply. the trafo has to have a little bit more (76V output) because of the losses.
the idea to put the amps beside the speakers is interesting but impossible in my case, i just can't split them off...
no answers yet.
Where did the 2A come from?
Where did the 180W come from?
Are you using Vac or Vdc in your voltage specification?
no answers yet.
I'm using AC.
The 2A and the 180W come from the shematic I'm going to use for the power supply. Those are Maximum values by the way.
you are arriving at the PSU specification from the wrong end.
Start with the power amplifier and use that as the basis for deciding what size the PSU should be.
What speaker impedances are you planning to use?
What power do you expect from each amplifier?
What voltage does each amplifier need for that required power?
ok, maybe you don't really get what i want so i form my question diffrent this time.
I have 5 amps and i need a power supply for them.
one amp: PS: +/- 30V, max 2A, ~100W
is it better if i use one trafo for each amp or is better to supply all five amps with one trafo.
Sincerely,
Wolfi
Sincerely,
Wolfi
Have you considered using a switching PSU?
I read somewhere that Coldamp SPS30 (as SPS80 is way too big for you) can be made with custom voltages. You can ask them, they are quite helpful.
I have one SPS30 (and several SPS80) and they run very well, no noises at all in my amplifiers.
- Power Supplies
- PS for 5.1 Dolby Digital System
