Prototype board and component stands
Some starting points for your research. It looks like Mill-Max offers a variety of plating choices.
"Standardized Turret Terminals" at http://www.keyelco.com/products/standard-turret-terminals-prod.asp?SubCategoryID=105
"2355 - Brass Alloy Turret Terminal Pin" at http://www.mill-max.com/pin_rec_cat...e=0.073&bodylength=&search=&pr=pin&stagecode=
"100 Mil-Spec Double Turret PCB Swage Mount Terminals" at http://www.ebay.com/itm/100-Mil-Spe...241&pid=100011&prg=1080&rk=1&sd=200564132779&
"(10) Dual Turret Swage Terminals DIY PCB Tube Amp Preamp" at http://www.ebay.com/itm/10-Dual-Tur...mplifier_Parts_Components&hash=item27ccf77acb
You need some specialized tools to install these things, but you can make the tooling from bits of steel, bolts, etc you have laying around under the bench or purchase at a hardware store. (REAL hardware stores are almost extinct but the "home-center" chains can supply the necessary materials if your moral standards will tolerate doing business with them.) See "How to Make Top Quality Turret Boards (with simple tools)" at http://site.tubedepot.com/pdf/turret_boards_v1.pdf
Dale
