jacquesl said:Do anyone know how to build a Proton Precession Magnetometer ?
Try to google this
"proton precession magnetometer"
Heinz!
Re: Re: Proton Precession Magnetometer
That might be a good idea but it doest help me so much they don’t give enough detail about this device
powerbecker said:
Try to google this
Heinz!
Have you tried this site? http://www.portup.com/~dfount/proton.htm
Lots of info and reference material.
Yip, I’ve already found that site, it doesn’t help much, it lack a circuit diagram, and it doesn’t seem to work, I’ve all ready build it
jacquesl said:Yip, I’ve already found that site, it doesn’t help much, it lack a circuit diagram, and it doesn’t seem to work, I’ve all ready build it
Last year I want to learn more about this topic and I buy from here :
http://members.aol.com/phil770/index.html
a CD with a lot of info, also circuits. I don´t remember the price, may be 30$...?
No, I don´t build this thing...I like to get informations !
Heinz!
pinkmouse said:And this has what relevance to audio? 🙂
Pinkmouse,
1. It´s diy and 2. it produces a interesting sound 😉
On the CD is also a wav file, but it´s too big to post it here!
Heinz!
PS
Oh, I forgot, of course it needs a amp and a speaker
This is the "everything else" forum.
I_F
I have used them, not build them.
The sensor of a PPM is a torroidal coil (in fact there are three at 120deg in a marine type) immersed in a proton rich fluid (filtered kerosene). The coil is fed with a polarising dc current (about 8Amps)for some time. This polarisation current aligns the protons in the fluid, in one direction.
The sudden collapse of the magnetic field, when/after the current is stopped, causes the protons to precess.
The precessing protons induce signal in the coil. Normally same coil is used for both purposes. A preamp and tuned circuit is used to amplify the signal.
The diagram i have is on big blue prints.
Gajanan Phadte
I’ve already have a bunch of info from Google, but its all 🤐
I should like to see a working with circuit diagram like that.
And the other thing is:
I’m, not 100% sure how it work or look, but does it print an output to your monitor like a radar and how does it all work.
Underwater night vision long range video camera or something
Are normal tape water a proton rich fluid can anyone name some common proton rich fluids easy to obtain, I’m in South Africa, uranium and all that stuff is not available for our use 🙂
It measures total magnetic intensity of the earth, and gives one reading per polarisation. No scans on monitors.
A PPM will give u only a readout. The display/measurement elex is just like a frequency counter.
It is a geophysical instrument and at the most can be used to find a sunken/buried magnetic, relatively large body like a sunken ship/aeroplane
Gajanan Phadte
Gajanan Phadte
- Design & Build
- Equipment & Tools
- Proton Precession Magnetometer
