i need a circuit of Amp protection to the out (short protection).... with Relay it will be good...
http://sound.westhost.com/project33.htm
This is a DC protection circuit, to prevent the speakers from blowing in case of amplifier fault. It doesn't protect the amplifier itself from blowing up.
/Freddie
I'm not quite sure what you want, but all electrical equipment should have a built in fuse in before the transformer. This will blow in the event of a problem.
Dj BASS AMP said:there is other short protection to the amp ?
Randy Sloan's “universal audio amplifier auxiliary control board” works good for 350 watt Mosfet amp I have
http://www.sealelectronics.com/kits/index.htm
- protection
