proper ferrite bead usage
I'd like to ask for advice on when and where in the power supply the ferrite bead should be used. Also, I see there is a large selection of iron powder RFI filters and how do I select between ferrite and various types of iron powder beads?
Actual problem:
I lost the ferrite bead that was on the power supply wires of my SMPS for a mixer. The SMPS outputs +/-17v dc. I remember the bead was about 2cm outer diam and had 2-3 turns of wire on it. What would be the right bead to use in this application?
thanks,
Herman
Did the bead have all three PSU wires going through it? If so it was a common-mode choke, practically any bead the same physical size is going to work.
As regards iron powder vs ferrite, iron powder can tolerate a higher maximum flux so is suited to where you need higher inductance and/or a higher current capability.
Its possible to improve the common-mode choking effect which often improves the audio quality - a few turns through a bead only has significant effect at RF (MHz and up) whereas the switching frequency (normally tens of kHz, plus harmonics) is the primary cause of audio degradation. To suppress CM noise down to 50kHz or so a significantly higher inductance value is needed. You can achieve that with more turns on the bead or with several beads in series.
Adding extra turns will improve the lower frequency filtering, but reduce the higher frequency filtering. It is the latter which may be needed to pass EMC regulations. Better to put two filters in series, so each is good for its own frequency range.
Common-mode EMC chokes usually use ferrite, as this is usually deliberately lossy so that you make a filter and not a resonator. Iron dust is more commonly used when you want to make an inductor or an HF transformer.
