Hi!
Just stumbled across a 2-ch plate amp from Hypex Electronics B.V.
The concept of a PC programmable X-over /filter really sounds great.
I was originally planning to build an analogue X-over for my active Speaker project by measuring the speakers and then calculating filters which would "hopefully" give me a good result. and then measure again.
Obviously, this would be an iterative process that would take a lot of measurements and re-soldering of the filters.
Being able to configure a digital filter "on the fly" whilst measuring the results of any iterations would be just so much better!
As I've already buildt some really nice amps, I'm really only after the filter functionality of the Hypex module.
Does anybody know if a programmable X-over board with software is available in kit or ready-made form?
I know there are some fancy DSP boxes out threre, but I just want a board that I can integrate in to the multi-channel amp just like an ordinary analogue filter board.
DCX2496...I am trying do rip out the heart of it, the DSP board and fit with separate I/O level converters and PGA based volume control to fit into a multichannel amp, but as any diy project there is no project time plan...
but there is groundsound.com, a countryman of yours...
Thanks for the tip!
Something like that DCN 23 board is just what I would be interested in!
But I must say the price is perhaps a bit on the steep side, especially as I'll need two of those and the software..
Found this company called redrcoks Red Rocks Audio
They also have a DSP module which looks very interesting.
Unfortunately, there is no pricing or ordering info available at the time.. 🙁
Sometimes you will have to pay some serious money to get a serious product...
DCN23 can be operated with the "old" free XOverWizard software - download here: http://www.groundsound.com/technical.php
Robert
Robert
THis is cheap:
C5000 DSPs What's New from Texas Instruments
Add a pair of DAC's interfaced via I2S.
Need I say more...
What kind of drivers are you using?
Which amplifier modules did you build?
What kind of money did you spend on these?
What do you expect from your project?
Robert
Robert
True Robert,
I have spent some money on other parts of my project as well, so in that respect, a pair of Ground-sound DSP's wouldn't be a totally disproportionate cost as such.
I'll have to give this some serious consideration, the money is not there at the moment, but the benefits are very tempting!
Thanks,
I can recommend the customer gallery section:
Ground Sound/customer
More customer galleries will appear in the near future, so check it out from time to time. 😀
Robert
Robert
Not sure if I can publicly disclose RedRocks prices, but their DSP is significantly less that the list price of the DCN23 kits.
Send me a PM if you want more information.
As a alternative, you could also look into the Freescale Symphony Soundbite: basically a Motorola 563xx based DSP board with onboard AKM codecs and everything. It's not lightning fast at 180 MIPS, but should be enough for iir crossover work and at $150 quite a nice package.
Thanks for all the info regarding developers kits!
However, I'm not quite sure if I'll be venturing down that path, looks like it is necessary to do quite some configuration and programming with those beyond just plugging in the parameters.. My experience with DSP's and more advanced digital electronics is limited to say the least, and although I could probably dive in to it, I need something I can get to work with a modest effort, lest I'll never complete my project! 🙂
The Motorola DSP is obsolete in the sense that it only operates with 24bits - you don't get much High-End processing as they claim. The DSP56371 were top notch in the mid '90...
Well, that obviously needs to be considered, I don't wish to sacrifice sound quality because of inadequate processing capacity or other issues..
Double precission is always an option, and going floating point will have a significantly higher price tag. TI has some evaluation/development boards for the 67xx floating point dsp's but these are imho too expensive for crossover development.
But even an 150-ish MIPS legacy Motorola will be able to do quite complex crossover work. As long as you stay away from long FIR filters, dozens of biquads on decent (96k) samplerates with double precision shouldn't be a problem.
As far of ease of programming, there is a certain learning curve involved. Most eval-boards will ship with decent tutorials an most often a dsp-library, often featuring standard processing elements like FIRs, IIRs and FFTs.
The Red Rocks miniPROC is a good bet then. Reasonable cost, system level programming and from what I've seen, it does it with pretty good dynamic range. Based on TI TAS3103 audio processor it has all the blocks for an XO.
http://focus.ti.com/lit/ds/symlink/tas3103.pdf
miniPROC is only 1-in 2-out but uses highly regarded Wolfson WM8740 DAC.
Haven't got it dialled in yet so no judgments on SQ yet.
Gooki: have you had any USB problems? I got one board won't enumerate with XP.
PC programmable with analog I/O. Nice, depending on exactly what you intend to do. But depending on what you do want to do, adding another 2 channels of audio output to your PC and some software might be all that is required.
w
w
Hi WB,
That's a valid solution too. I wanted to run a balanced line to each speaker and then have the speaker do it's own XO and amplification. Ultimately part of a networked system.
Never found the need to invest in fanless PC's so the PC has to be exiled to a remote closet. Wifi isn't reliable here and I haven't run CAT5 everywhere......yet.
For now it's best for me.
A cheap digital x-over would be from MiniDSP, and it's very easy to use. I'm waiting for the digital in/out module, so can't say anything about the sound quality.
Welcome to CAD AUDIO DK has also a range of cheap x-over modules.
At the moment I have Behringer DCX2496, it's ok but too much noise, and to big to fit in a loudspeaker or amplifiercabinet.
- Digital Line Level
- Programmable Digital X-over board?
