Proficient Protege FS12
Hi, not sure if this is where this should be posted. I have 2 Protege FS12s. Both doing the same thing. A low buzzing noise in the speaker with no signal turned up. Thought it might be a noisy op amp. Replaced all the op amps on the board. Still noisy. Anyone else run across this? Thanks.
