hi i was getting problem with log in in this site .
when evere i loged in then i copyed url topast another broweser but i didn't get login at thje same user id..
andrew
Sena smh10
andrew
Sena smh10
Have you tried just typing www.diyaudio.com int the other browser? You should be able to log in that way. The forum uses a cookie to identify you. Once set, you should have no problem.
