problem soundstream d200
hi! i have a problem with a faulty soundsteam d200, which i am trying to repair. the amplifier was in very bad condition and i tried to make it new again. I replaced all the bjt mpsa 42 and mpsa92 with new ones, the diodes in914 d1 d2 d3 d4, the tip 142 and tip 147 resistors and everything practically as new.
the amp turns on the pwm works the 36v duals are there, but at the base of the tips 142 tip 147 come -33v. so there is some problem that i am not able to understand usually there should be small positive values at the base of the power amps positive for npn and negative for pnp, and not -33v at the base of the power amps!
the only thing I can think of but it is not possible because they are the same in914 I supported them with in4148.
thank you very much
I'm sorry, for the translator I know it's not perfect! I solved the problem was mpsa42 of the bias at a loss.
The only thing, the tip 142 tip 147, the original sgs ones are no longer found. But the tip of the st that are now made in China ...
