Pro-ject Genie bearing size
Hi guys,
could someone tell me what the size is of a pro-ject platter bearing? More specifically, I am interested in the size of the hole in the platter. I found an interesting platter on ebay that I would like to fit on a pro-ject genie. I am aware that with a new platter I should check that the ration between platter diameter and pulley diameter is the same (so if someone could give me that ratio as well, then that would be great! Alternatively you could give me platter diameter and pulley diameter, then I can work it out myself...)
