The motor suspension band on my debut-iii has perished and broken. I'm pretty sure that I lost a section when I was removing it, so am not sure of the correct size. Anyone got one they could measure ?
It's basically a big o-ring, so I'm wondering if there is a cheaper alternative out there that would be cheaper (or indeed better) than the $14 an OEM would cost after shipping.
Project 1 band is around 170mm circumference, don't know if Debut uses same band.
Try Pulley Belt 2.5mm x 50mm ID if you are a heretic.
Or look up Project Upgrade kit - more money but search online for Project rumble and see if you think it applies to your turntable.
Thank you for the response.
My turntable didn't suffer from the rumble or hum that others seem to do. Maybe it will after I replace the motor suspension band with a cheap non-OEM solution ? 🙂
