Prism DScope as a Soundcard?
Is there a way to use the analogue inputs on the DScope to record into an editing package such as Audicity / Reaper etc?
It's not been seeing a lot of use at the workshop, as we have other AAs from R+S, AP etc. I was thinking that were the DScope to work well as a soundcard, it could be useful to have in the home system - enabling one box to record, as well as run health checks on the home setup.
Thanks in advance.
Just how hard would it be for someone to write a piece of code that enables the DScope to work as a soundcard?
Anyone?
USB has a number of standard “profiles”, some such as the audio profile are well documented whereas data pipeline houses the setup but not the proprietary control messages.
Two options really:
1. USB audio profile - the device would have to support the USB audio standard and therefore it would simply become a sound card/microphone.
2. Use the existing VB links and code a sound driver on Windows to use the script links perhaps?
Some USB devices download firmware on connection into the device - Cypress USB chips did this quite a bit. So without having the device operational and a USB analyser running it’s difficult to say.
That is assuming the existing software support doesn’t provide sound driver support for Windows.
Thank you!
IIRC, the DScope does this. I seem to remember that there's a pop-up box telling you it's installing a driver, upon first connection to a new machine.
Something I just thought: the DScope has a fairly loud fan... Maybe it's quite easy to configure for home record / play duties, but no one's bothered for that reason...
