Hello,
I have searched these forums as many ways as I know how to find a printable template for the 167E or similar sized driver, no luck yet. Can anybody point me to the place where I can find this one?
Thanks,
Jeff
Thanks,
Jeff
How to use
Hey, thanks! I was trying to figure out how to best use the template. Do you actually cut out the black rectangles and place the template over the cone then paint through the holes? Or is there some other method to best use it? Cutting out those holes would be very tedious for sure!
Jeff
Jeff
No. You just print them out with an appropriate scale to lay down a row of spots, and then use the 1st row to do the 2nd row (and the 3rd if you are talking about the whizzer). Something like 90% of the main cone for that ring, 95% for the whizzer. The linear template is useful for dustcaps or inside-out for the bottom whizzer ring if you remove the dustcap. With the pattern facing out the linear ones are what i use to put the spots on the phase plugs (real tricky to get these exactly the right size)
dave
dave
