Yep. The turns ratio is 900:1, so 7200 ohm pri for 8 ohm sec. I measured two and were the same. You might have had a typo, but it is 6BQ5 tubes not 6BQ6
Sorry, I should have said 900:1 IMPEDANCE ratio, so 7200 ohm pri. impedance for 8 ohm sec. Turns ratio is 30:1.
