Precision Power PCX2200
I believe its rated at 50 watts by two channels into 4 ohms or 200 watts rms bridged into a 4 ohm mono load. It could probably run two efficient 10's in a ported box, but I wouldn't try to run 12's if you want it to sound good.
That might be peak power. How long is the amp? I get the models confused since the later ones tend to use the maximum continous power as the model numbers. If its 200 by two into 4 ohms, then yeah.. its a powerful amp. I'm pretty sure it isn't 800 by two bridged, but it could be 800 watts bridged into a 4 ohm load. It would need to be around 18 inches long. What are the measurements?
Channel: 2
4 ohm: 200
2 ohm: 400
Bridged: 800
Damping: >500
S/N Ratio: >115dB
Dimension: 2.375" x 10"
Length: 18.5"
THD: 02%
Power Input: 4 Guage
Freq. Resp.: 4.5-100k
I/P Sens.: .15-12V
X/O Slope: 12dB
X/O Freq.: 30Hz-4KHz
X/O Type: 2 way
Input Type: 12 vDC
Cooling Fan: yes
QBass: QBass™ Plus
