Precision Fidelity C8 pre
I have a C8 preamp. I have replaced many of the parts in it but it still has a hum. The only parts that haven't been replaced are the large can caps. They are 35 years old. Could this be the problem?
They started long before I swapped out any parts. I was beginning to wonder if some of the PC board traces were bad so I pulled a couple and hard-wired them. I also tried bypassing the cans but of course that didn't do anything.
Can you tell me the value of the smoothing or PSU caps by the schematic? I am not a technician but I can replace parts well. If the abbreviation for PSU is power supply unit then yes, I know. I am thinking of just getting a few 400V solens. It will be hard to fit them but I will make it happen.
Shane...the probability is that one of those can caps is bad. If the can cap is (multi section electrolytic capacitor), get some caps for each section of the can, and wire those caps across the corresponding section of the can (watch polarity and markings) and see if the hum disappears. There has to be a source for the can caps....Be very careful working with the can caps...the bakelite wafer support is brittle and it will break easily.. If the can cap is actually bad and no replacement can be found, some "purists" will save the terminal strip from the can, and gut the contents, wire replacement single value capacitors for each section inside the can, and reseal it...
Shane...you could probably get 4 of those 30 uF caps in that can. Surprised the preamp has a BJT (bipolar junction) output...I would also check the 10,000 uF cap on the low voltage heater supply...look at it with a scope for AC ripple, or substitute another capacitor...the 10,000 uF cap may also be a single section metal can unit....
REPLACE the voltage regulator on the heaters also . Those thing are much improved in 35 years and very inexpensive. If you are up to it replace it with an adjustable voltage reg it is quieter do to the cap bypass on the adjustment leg as well as setting the voltage closer to the 12.6 volt heater point . The last is not that big a deal as 12 is close enough given it is regulated.
Yeah, there's always the diminishing returns.
So, Soda, judging by the schematic. those are the right caps for me to buy? I am going to pay someone to put them in for me. I just wanted to check in with one of you guys before I spend the moolah.
