preamp
i can´t answer your question, but i decided to make bride of zen, because i don´t own any balanced source or amp, and i think simplicity has it´s own aesthetically quality. I´ll build it with a array of relais instead of the pot for volume control, so this part will be more complex than the main circuit.
If You decide to make a blanced, why not this? http://www.diyaudio.com/forums/showthread.php?s=&threadid=3205
or as Gabster (thanks to Gabster) gave the link : http://www.passlabs.com/pdf/aleph/apserv10.pdf
