preamp help w/ critique
ok, i need some major critique on this mic pre i laid out. My main concerns would have to be my ground planes. its a double sided board and in a sense maid 2 different planes that come together at one point. (top plane, and botton layer plane) Is that a bad idea? Could or would this cause problems? also my other concern is my discrete buffer section, after the pot and before the line driver. Not sure if i laid out that part correctly or not.
about the pre: its basically a mic pre that is based around the INA217, but can be used with THAT1512, 1510, and SSM2019 with little or no mod. Nothing to it really, very simple but i dont know enough to design something great. I've been slowly trying to get this to a point to where it would be worth it to get a few boards made.
