Preamp for LR Baggs M1
Hi All
I am putting together a belt preamp for a new Takamine Triax pickup (LR Baggs M1 essentially) for my acoustic. This pickup has an output of around 100mV maximum and therefore I need a little over 20dB of gain. I also want a volume control and low output impedance. I have put together the circuit below based on a OPA2134 op-amp (a little over kill for this app, but I need the headroom and very low noise)
I wondered if you could advise if it would be better to configure the input op-amp as unity gain and use the op-amp after the volume pot to provide all the gain, or as shown, share the gain between both op-amp sections? I am thinking that if the input op-amp had less output, this may lower any pot noise when adjusting the volume?
Also do you guys and girls think the component values I have in the feedback loops etc will result in good low noise and good fidelity operation?
Any improvement suggestions are very welcome!
Cheers
Ray
Hi Nigel
How are you doing and thanks for your reply!
I wanted to put the volume pot in front of the op-amp on the output so that I always have an unaltered high impedance input and low impedance output. With a pot directly across the output, the output impedance will alter depending on the pot setting and generally always be higher than without the pot.
If I use the first op-amp as unity gain (so just a buffer), do you see any noise problems, or other, with running the second op-amp at the required 20dB gain?
Cheers
Ray
Hi Nigel
That's why I specified a 4.7K pot, that's low enough to fed the 20K input impedance of the following amplifier.
Like I said, it makes no difference at all - you're only talking about very low gain figures, and a high signal level to begin with.
I doubt you will be able to hear any difference no matter how you do it, not measure any difference either (including the single opamp version with a 4.7K pot).
