Hi guys ! I know there's some of you who buid nice preamp with source select button, rotary encoder and lcd panel to show everything. Actually, i based my research on Suzy J. preamp. From the beginning to right now, i'am stuck with the code. I use a pic16f887 and program it with pickit 2, mplab with either CCS compiler or Hi-tech (Depend of the soure file). Doe's someone can help me to program my pic ? If you have a god set of routine that are working whatever 4 bit or 8 bit or serial it will be appreciate. Currently, want i can do is to put strange character on the lcd via rs232 connection.
Thank's for your help !!!
