Pre/power amp question...
Hi ya all!
I¡?m building a pre/power amplifier combination where power amplifier will actually have four amplifiers inside for bi-amping purposes. I¡?ve two ideas currently on my mind and I¡?m not quite sure which one is going to be:
a) Power amplifier will be placed between speakers, active crossover will be inside it and the signal from the preamplifier will travel in a balanced manner. For: very short speaker cables. Against: Low level signal passing through long balanced line (although there is a buffer behind the volume control in preamplifier).
b) Power amplifier and preamplifier will be placed together, away from the speakers, active crossover will be placed inside preamplifier. For: very short interconnection between preamplifier and power amplifier. Against: Long speaker cables.
Now, there are few more ¡§for¡¨ and ¡§against¡¨ for each of those topologies, but I¡?m not into typing right now ?º¡K
Anyway, what do you think? I like the a) solution a little bit more but I¡?m still banging my head about it¡K
Thanks in advance!
c) classic active speaker (2ch amp+XO in speaker)+ separate bal. preamp
d) my suggestion: 2ch amp + XO in one chassis, separate preamp. Then you can do experiments with amps positions and all cable lenghts.
I now what you mean and I understand you. But: THD and IMD inserted is about 0.001%. Many listening tests were done, speakers as good as Wilson Audio Maxx, B+W Matrix 801. Also small 2-way bookshelf speakers. Improvement is incredible (tough bass, pure mids and treble, no grain). I would not believe it if I did not build it and listened to it. The circuit can be implemented as an output stage of a preamp.
PMA: And I understand you... But take a look in this forum....
Why do you think that there are so many discussions about circuit design??? Because ALL circuits adds or deducts something...
Chech even the Pass forum. Mr. Pass is quite intelligent and good at designing circuits, however they can still be mproved.....: bigeyes:
You can compare your suggested buffer to any amplifier circuits,
- meaning that there are 1000 ways to do it, each with its own advantages and disadvantages...
So my oppinion is still:
Bad sonic sound is rearly caused in high power cabels.
They are caused by bad circuits and inprober low level signal cabels... No offends!!!!
Jan,
that's why the influence of signal cables is neglected by the Buffer, and the cable must be terminated (R10 and R12), probably to suppress dielectric phenomena. This was also difficult to diggest for me . I am an electrical engineer as you, for all of my life I've been designing circuits and instruments. Graduated in electro-acoustics 😉 .
It is interesting, but even a 50 cm of non-buffered non-terminated signal cable makes a trouble. And speaker cables? Forget that they are all the same when having high cross-section area. The better sound chain you have, the more you are able to distinguish. The experience is not transferable, so I am not going to argue more 😉
Pavel
