Is there a integrated tube amp whith a pre out?
Could it be done?
It would be great for us whith a sub....
Could it be done?
can be done quite easily. You can take the signal after the volume control, in the attached schematic the author uses a cathode follower after the volume control of the amp, to 'isolate' the sub amp from the rest of the circuit. I believe it is a good practice.
http://www.jogis-roehrenbude.de/Leserbriefe/Klaus-PP/Push-Pull.htm
Erik
Erik
