Pre-condenser fresnell ?
I though it would be an excellent idea to use a pre-condenser lens (fresnell or other) between the lamp and collimating fresnell. If the lamp is 14" from the fresnell the fresnel will gather only a small partion of the light the lamp is emitting. Using a pre-condenser you can actually increase the intensity of the light from that lamp. So how to calculate the FL and optimum distance from the lamp for the pre-condenser, and where to get such fresnell? I guess the total FL is calculated from 1/FLtot = 1/FLpre + 1/FLcoll, but how to select the first two (FLtot and FLpre) and where to put the pre-condencer fresnell? I know some people use regular lenses placed as close to the lamp as possible, but is it actually a better way to go, will the small lens gather enough ligh?
Obviously a fresnell close to the lamp is not a good thing, it needs at least an e-glass between and it simply doesn't work well if the angle of beams to fresnell surface is too big. Any ideas?
Wow, it is expensive! Ask YWH if he can get you a cheap one. Even better, ask mikekniner, since he just bought a box of 3m optics, there ought to be some condensor lenses among them.
The lenses in 2nd link are too small. but you can use it if you have a reflector like the one listed in
this website. the reflector actually collect all lights to a smal point near the condensor lens.
