Im working on this amp It had a blown power supply.
I fixed the power supply amp powers up but the right channel has 25 volts dc on it.
I removed the outputs and drivers for that channel Still have 25 volts on the outputs .
Any thoughts where to check?
Ok nevermind .
Upon further inspection i found 1 of the boards in the output section that is cracked almost in half.
Anyone have 1 of theese boards i can buy from you or know where i can get them??
