Would anyone happen to have a working knowledge of the video and power pinouts/requirements for the Powerview 950? Info on it seems to be extremely scarce.
-Adam Wise
RPI '07
-Adam Wise
RPI '07
Any use?
http://www.diyaudio.com/forums/showthread.php?threadid=9142
On the VGA side of things the general opinion appears to be that all infocus panels use the same lcd pinout - in which case the this should help:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=34848&highlight=
And I still have the 26 pin plug, so email if you want it.
JT
JT
the only site i found to have anything to do with the pinout for the powerview 950...look under other cables
http://www.infocus.com/service/tech_library/cables.asp?site_lang=1&site_region=1&
JohnT: wooh, thanks, that does help! I would imagine it wouldn't be hard to jury rig an ATX power supply to get what I need out of that sucker. And also for the concensus that all infocuses use the same LCD pinout... what a relief!
Dengez: Ahh, it's so strange that that's the only mention of the 950 on the whole damned company site.
Thanks for the replies,
Adam Wise
RPI '07
Adam Wise
RPI '07
