PowerSoft DigiMod 1000 (Where to get)
I have PowerSoft DigiMod 1000 module on the bench from a RCF ART522A power speaker. Seems RCF use these modules OEM..
Apparently there was phase issues at a gig took out a number of items including this RCF. I believe they could have been exposed to over 250Vac!
IGBT's in the supply SC, One channel the MOSFETS S/C taking out 4.7R 7W resistor and number of SMD diodes.
I could spend time fixing it however, I know these are available as a complete module OEM and rather replace the module than spend $120 AU on parts alone not including labour..
The DSP plug in is good so I'd be happy with a module without the DSP card as it's setup with settings.
Anyone have these in stock? How much (Can do a PayPal transfer)
Freight to Victoria Australia. Because I'm in Australia Everything here is so expensive, because of the "Australia tax"
Rob😛
