power supply sizing recomendations please
I want to build 2 monoblock power amps and i tipically want as much power as possible but also a high current amplifier because i will driving full range ribbon speakers with them.
I was thinking in continious power range of 200 watt/8ohm, 400 watt/4 ohm and 800 watt at
Because I lack the knowledge and experience to be able to build a complete amplifier from scratch i've decided to use the LC audio zappulse 2.2 se modules.
I currently run these modules in a temporary setup with a 50VAC / 500VA transformer and a PS with 12*4700uF capacitors (for 2 modules!) This is defenitely not sufficient for my speakers!
At first I wanted to install (in each monoblock) a 2*50V / 1000VA transformer and 2 pcs 47000uF capcitors, but if I use a 45VAC transformer I can use 4 pcs cheaper capacitors (63V) for the same price.
I'm also lookin at choosing 8 pcs 22000uF per mono amp but this would cost more at less capcity.
Any suggestions what would be the better choice?
BTW i want to build the PS as suggested on this page:
http://www.zero-distortion.com/techno/powersupply/powersi_05.htm
so I've also done the calculations on the next 2 pages of this site
thanks
Eric
You'd want slightly lower rails than 63V if you were to use 63V caps (the mains current can vary, under no load the voltage would increase a tad bit if the trafo is specced under load).
I'd go with a 1000VA/40VAC with good regulation which ain't a problem at this size (or 42VAC -for the sake of it- if you can custom order)/with one bridge/94.000uf/63V per rail/monoblock, for ribbons you don't need lots of power in the 8ohm zone, but large current capability in the 1-2-4 ohm region.
Guido's a lot bigger capacity in his amps and a lot lower voltage.
The soundquality in the treble region is considerably better, only one track of a record showed that immediately.
I'm not sure if this is because I run the modules at the limit voltage or just because of a too small ps (I expected that the bass would the biggest difference if the supply is too small)
I will probably make something similar like him with 42 volts transformers.
With a 1000VA and 42vac secondaries, the DC rails will be about +/-58v dc. I built one amplifier with the above with 30,000uF per channel.
I could not get more than 165w into 8 ohms at clipping...
Not sure you will get the 200w @8E you are looking for but then would you need it?
Cheers! 😉
Hi I updated the transformer to 1000VA 42VAC and the amp improved dramatically, treble, bass and soundstage.
I now will look for very good 63V capacitors to finish the project.
I'm thinking of BHC ALS30 or BHC Splitfoil (more expensive)
any other suggestions?
