Power supply question
First, what are the power requirements for the amplifier you're building?
There're a number of ways to use multiple transformers together, but whether you can actually use any of them to power your amplifier really depends on the voltage/current requirements of that amp.
u can connect the two 2*40/150VA transformers in parallel , be carefull while doin so ,u got to properly phase those transformers.
imho u cant connect the other toroid because it got different power rationg , connecting different power transformers is not reccomended plus it got different voltage out !!
