Power Supply Pumping with full bridge
Power supply pumping is an essential part of class D efficiency.
Think of it this way, what you have at the switches output is a square wave. Desirably you pass it through a purely reactive filter to get ride of switching carrier and harmonics and recover the original audio signal.
Now, where does that not negligible energy goes? Back to the power supply via the freewheeling diodes across each switch.
It is not a bad thing at all if some care is taken with design, in this case ample bypass low ESR capacitance across each power supply output. Non rechargable batteries will no suffer as long as most of the returned energy is stored in the capacitors, meaning the PSU does not rise but a few percent during the return current pulse.
Rodolfo
