power supply for source follower.
A 18VAC transformer that can handle the current, yes.
I guess this is for your choke loaded follower project, right?
I´d suggest a 2x18VAC >300VA toroid transformer.
Use one secondary per channel, 2x3A is easier to handle than 1x6A.
Yes, two 18V 10A windings will be fine. If you want 27V rails (as mentioned in the thread about the amp) you´ll need slightly higher voltage, say 20-22VAC.
A regular but big bridge. 35A is fine.
I´ve read somewhere that one always should have more capacitance after the choke than before it. Ringnings and stuff I guess.
I guess Hammond has suitable ones.
Hi Audio Geek,
Do not resign from soft-start circuit if you plan to use toroid trafo and large capacity. This simple circuit will reduce big curents charging capacitors on start-up and avoid from accidential fuses blow.
Regards,
Marek
You might not want to mess around with choke input filters.
Works fine electrically, but finding a choke that doesn´t buzz is not easy. They need to be big (as in BIG), too.
Been there, done that.
A suitable choke for LCL filters might be this one:
159ZG 15mH 4A
Say, 2 x 22000uF - 159ZJ - 4 x 22000uF. Per channel.
If you want to run two channels on the same rail, double up the capacitance and use a 159ZL choke instead.
Make sure that the caps (at least the ones prior to the choke) can handle some heavy ripple currents.
Dirt cheap? Nope, but if this is a serious project you won´t regret spending some hard cash on the caps.
Speaking of caps, put some film caps (1-10uF) across the `lytics.
A 10nF/10R serial network across each diode in the rectifiers is nice, too.
With a capacitor input filter the output voltage is about 1.4 x the transformer AC voltage and you can pull about 60 DC watts for every 100 transformer VA's.
With a choke input filter (provided the choke inductance is greater than a reasonable minimum value) the output voltage is about 0.9 x the transformer AC voltage and you can pull about 80-90 DC watts for every 100 transformer VA's. Under very low load the DC voltage rises toward 1.4 x the transformer AC voltage.
Use them!
If you don´t want to take chances, put them after the choke and buy some others for the "before choke" position.
You can also put one or two smaller caps close to to the Mosfet, 1000uF or so high quality low impedance stuff.
Remember, an amp is never better than it´s power supply!
All the amp does is to modulate whatever comes from the PSU.
Fuling said:
Sine shaped current draw instead of the spiky mess drawn by capacitors.
Actually it isn't! Sorry. The bigger the choke the closer the current from the transformer approximates a square wave!!! This should be even better than a sine wave because it spreads the current more or less evenly across the whole half cycle instead of concentrating it in the centre like a sine wave. Remember, The resistive losses in the copper vary according to the square of the instantaneous current so a square current waveform packs the most energy per half cycle for a given copper temperature.
Choke input or Pi-filter
You guys are confusing a choke input filter powersupply and a PI-filter.
For the first you need a minimum value for the choke depending on the continuous current while the latter will work with something like 2.2mH though I am currently using 15mH in my Ampzilla.
See f.a. Transistor Circuit techniques by G.J. Ritchie, Chapman & Hall, Third edition page 183 and:
http://db.audioasylum.com/cgi/m.mpl?forum=tweaks&n=27698&highlight=elso+choke&r=&session=
http://db.audioasylum.com/cgi/m.mpl?forum=tweaks&n=36470&highlight=elso+choke&r=&session=
http://db.audioasylum.com/cgi/m.mpl?forum=tweaks&n=41191&highlight=elso+choke&r=&session=
I guess the Cello power amplifiers had a huge choke input filter, at least that is what they claimed. The choke was as big as the transformer!:bigeyes:
Choke
The chokes I am using. DCR= 0.57 Ohm
