Power Supply for ES9038 PRO Based Boards
ASPS1 power supply is specifically designed for ES9038 PRO based systems. However, you can use it as generic power supply for other systems as well.
ASPS1 is "smart" power supply: it is microprocessor controlled, and its functionality could be extended at the later date. This sets it apart from other power supplies in this class.
ASPS1 Characteristics
  • Input power (max): 50W
    Output power at 15V (max): 20W
    Output power at 6V (each, max): 10W
    Input voltage: 100V - 240V, 50/60Hz, autoselect
    Power LED indicator control output (LED is not included)
    Power On/Off output (power switch is not included)
    Made In Canada
Note: If you require DC voltage for your system, you will need to build your own linear AC/DC converter and connect it to ASPS1.
Asking $199.
