Hi I seen a few q's bout this panel and I seem to be the only one witht he cables, the info below should allow you to replicate the power supply
I took some pics of the supply, here they are
http://www.onlinething.com/power
the top of the power unit reads:
"ITE POWER SUPPLY
INPUT:100-250v~50-60hz 1.2A
OUTPUT: 15V 2.7A
Theres a little diagram then of the pins.
0 B
A B
A 0 0
Ok theres 7 pins,
The pins I have marked A e.g (2nd and 3rd from the top
left) read +15v, the top two pins tot he right e.g BB read 0V
Hopefully the pics will help a little there.
On the other side it says model NO: UP30435
Hope this helps.
PS sorry fro pics camery battery has run out, if u
want more u'll have to wait a few hours for it to
charge 🙂.
Kind Regards
Joe
"ITE POWER SUPPLY
OUTPUT: 15V 2.7A
0 B
A B
A 0 0
Ok theres 7 pins,
Hope this helps.
charge 🙂.
Kind Regards
Joe
7-pin power cable
do you still have this cable, or are in need of it? I need it for my 3M 6450 and have trouble understanding why there are two pins with a +15v charge and which they correspond to.
