I'm building a 5AR4 rectified power supply for a preamp I have with one ECC40 valve in it. It's been designed to output 440V HT. As I don't have a variac, would a high wattage dummy load resistor be appropriate?
R = 440 / 30 is about a 15 ohm load. What would an appropriate wattage be? Thanks!
30 amps current ??? I don't think you mean that!
30mA makes it 15K, much more reasonable.
W = VxI = 440x0.03 = 15watts approx. So a BIG resistor or a metal clad one on a large heatsink
Yes, but - 15watts of heat is a LOT!
So you need to check on the heatsinking, or use (for example) 10 1R5 5W wired in series.
30mA for a single ECC40??
It has a limit of 10mA per triode section and in preamp duty it is typically run between 1-4 mA.
A GZ34/5AR4 is serious overkill (250mA capacity) here too (not that that stopped me from putting it in a preamp 🙄)
You are correct. I got a wonderful deal on a massive PT pulled from a 1960s HF transmitter. The secondaries are:
(2) 5V @ 3A, 6.3V @ 5A, 12.6V CT @ 6A (for balance and noise suppression, thin gauge), and 350-320-0-320-350V @ 1A
I have two Leak preamps that I wish to provide HT and filament for, but not concurrently. However, I would like to expand it's load in the future to include an older Brenell three valve tape recorder whose power supply is fried. I am an amateur and this is my first PS design, though I do realise the GZ34 is a bit overkill for the inital singular valve. 🙂
P = E² / R
I = E / R
And per the original 'mishap' in calculation, don't forget milliamps vs. amps. I calculate about 13 watts on that 15 kΩ resistor. And yes, 10 ea of the 1.5 kΩ resistors in series would be fine. ALSO gives you a "variable resistor" at each tap (but watch the power!)
Indeed … you could put a series of them together
To make a universal resistance chain. This shows that if you were to standardize on 5 watt resistors, the chain has a minimum of 5 watts (of course, single resistor) of dissipation, and a maximum of over 50 watts, based on the “weakest link” being the final resistors. Note also that there are LOT of useful resistance values in the chain!
GoatGuy
I = E / R
Code:
¹/₂₄ >sum of last R 5
>R value chain of chain max of chain
1.0 1.0 100% 5
1.10 2.1 52% 9.5
1.21 3.3 37% 13.7
1.33 4.6 29% 17.4
1.47 6.1 24% 20.8
1.62 7.7 21% 23.9
1.78 9.5 19% 26.7
1.96 11.5 17% 29.3
2.15 13.6 16% 31.6
2.37 16.0 15% 33.7
2.61 18.6 14% 35.6
2.87 21.5 13% 37.4
3.16 24.6 13% 39.0
3.48 28.1 12% 40.4
3.83 31.9 12% 41.7
4.22 36.2 12% 42.9
4.64 40.8 11% 44.0
5.11 45.9 11% 44.9
5.62 51.5 11% 45.8
6.19 57.7 11% 46.6
6.81 64.5 11% 47.4
7.50 72.0 10% 48.0
8.25 80.3 10% 48.6
9.09 89.4 10% 49.2
10.00 99.4 10% 49.7
11.01 110.4 10% 50.1
12.12 122.5 10% 50.6
13.34 135.8 10% 50.9
14.68 150.5 10% 51.3
16.16 166.7 10% 51.6
17.78 184.5 10% 51.9
19.57 204.0 10% 52.1
21.54 225.6 10% 52.4
23.71 249.3 10% 52.6
26.10 275.4 9% 52.8
28.73 304.1 9% 52.9
31.62 335.7 9% 53.1
34.81 370.5 9% 53.2
38.31 408.9 9% 53.4
42.17 451.0 9% 53.5
46.42 497.4 9% 53.6
51.09 548.5 9% 53.7
56.23 604.8 9% 53.8
61.90 666.7 9% 53.9
68.13 734.8 9% 53.9
74.99 809.8 9% 54.0
82.54 892.3 9% 54.1
90.85 983.2 9% 54.1
GoatGuy
12,6V@6A thin gauge? 6A wire it's so thick you don't wind it on, you fold it.
If 6A I see a nice PP GU-50 power amp in your future 😉
That's how it is documented, yes. In reality though, the wire is only 20ga!
Goatguy- That is fantastic! I so happen to have a number of these onhand as well!
20AWG is that something like 1,5A? Preamp only I guess.
Did you measure the (unloaded) voltages? With no or a light load they could be higher than specified. When you load the 6,3V with considerably less than the rated 5A (i.e. a preamp) you could be overloading your heaters a bit. If it is just a single ECC40 you may as well rectify the 12,6V and run it through a regulator for 6,3V dc.
I haven't powered the supply yet. I am wrapping up construction as it is very much a homebrew. The design was done in PSUD2 by an aquaintance as my skill with computers is marginal. As I don't have a variac, I wanted to ensure I could test it prior to attaching the preamp.
The plan was to use the 320 secondary to mitigate the low load placed on the transformer with a single valve though your idea regarding the 12.6V tap is good. If I utilise the 6.3V for the heaters, I will need to either run it through a pot or a virtual CT, as it's lacking one.
I won't get back to this until this evening or more likely, tomorrow, due to work.
- Power Supplies
- Power supply dummy load
