I have some power supply boards for sale which are now surplus to requirements.
Each board is populated with:
- Two capacitors 6800µF/100V (in parallel)
- Two power connectors
- One rectifier bridge MB252W (200V/25A)
- One 20A fuse in the transformer AC input
- LED + resistor for a visual "power on" - can be connected
These are great for power amps, as they are (one board per rail). If you need a regulated power supply, you can populate the other components and have a LM317 regulated supply. Also, there is a transistor, which can be populated, for a "relay" control, if needed.
These are assembled in USA and only tested, never used, so practically new.
Will provide the exact schematic to buyers.
$25 each plus PP/shipping. Will ship at cost.
