I'm using a chip amp LM1875 with a protection relay to the speakers.
Relay wired to the amplifier in the NC terminals & ground in NO terminals, powered by a separate 12v DC wall wart through a switch on the front of case.
When I switch the amp off using the relays switch there is a slight 'POP'.
If I pull out the wall warts connector from the rear of the amp, no 'POP'.
So I'm thinking that the relay is sound, but the switch is causing the trouble.
I would appreciate any thoughts, I have seen reference to RC networks across the switch contacts, but I'm unsure how to calculate the values needed.
do you have a snubber diode across the relay?
If not, the act of opening the switch-relaycoil-powersupply circuit generates a very high voltage that radiates like crazy.
A reverse biased diode across the relay coil will stop that problem.
Akitika GT-101
Update My Dynaco
Akitika GT-101
Update My Dynaco
Looks like the wall wart switch is in the AC path and the filter cap V takes time to die out. Reduce the filter capacitor value in the wall wart to the minimum possible.
Gajanan Phadte
Gajanan Phadte
Thanks for the advice djoffe!
I tried your suggestion this morning with an ultrafast recovery rectifier diode I had spare from a PSU project (200V, 1.5A rated) and it works an absolute treat 🙂
Absolutely no noise on relay power off and on, I really appreciate your advice, made even better by the fact I had something lying around
a 1n4001, or a 1n4148, or a 1n914 all work well in absorbing the back emf of low voltage relay coils (upto 24Vdc)
