Hi all,
I would like to try to change the power cords in my system. What is the best solution for less then $41.50 USD/m (32 EUR/m) or $12.65 USD/ft? I am talking about bare wire - unterminated cables - I will finish them.
Thank you
Thank you
for a very good cable - three wire with screen and transparent surround - I pay less than 5 EUR. And that's only because of the looks, the same electrical and mechanical performance/quality could be had for less than half of that.
Don't get me wrong, but paying 40$ for a bare meter of asymmetrical mains wire is pointless with any kind of equipment. Of course manufacturers claim differently, but guess why... 😉
...but this discussion is ages old, too...
Sebastian.
Sebastian.
I agree fully with you sek, but maybe instead of teasing people with how cheap your cable is, what is it and where do you get it from? 🙂
It constantly amazes me how unfair people are. It's ok to pay double for a cable just because it looks like it's expensive but very silly to pay extra for superior sound?!
Hi richie00boy,
It's a german brand, so I don't know about availability near you. But the manufacturer Lapp-Kabel also has many distributors around the world.
I've seen it at www.conrad.com, but this one is usually not the cheapest. 😉
I attached a pic from the Lapp website.
Hi analog_sa,
Well, I guess you either misunderstood me or want to 'turn my words around'...
Neither did I state that I want my cable to look 'expensive', nor does it 'sound bad'!
I wrote that I like how it looks, that's the reason why I accept the still relatively high price. If it was only for the superior sound, paying more to replace a very good mains wire is what I consider pointless, as I said.
Sebastian.
richie00boy said:I agree fully with you sek, but maybe instead of teasing people with how cheap your cable is, what is it and where do you get it from? 🙂
Hi analog_sa,
analog_sa said:It constantly amazes me how unfair people are. It's ok to pay double for a cable just because it looks like it's expensive but very silly to pay extra for superior sound?!
Sebastian.
Home Depot orange. If it's good enough for a speaker cable hoax, it's good enough for power cable nonsense. And it frees up money for CDs.
analog_sa said:
People pay money for those things?
At least I pay for my blanks, I do not DIY them!
The Butcher😀
Does anyone have a link to something explaining the benefits of "audio-phile" power cables? I can't think of any benefits, unless they link my equiptment to a power conditioner of some sort, as otherwise, they are giving me an exact replica of the power at the outlet, which could already be full of EMI/RFI. I assume I am missing something...
I don't want to start anything here arguing about it, just looking for some more info, so you can email me the link(s) if you have them.
WorkingAtHome said:Does anyone have a link to something explaining the benefits of "audio-phile" power cables? I can't think of any benefits, unless they link my equiptment to a power conditioner of some sort, as otherwise, they are giving me an exact replica of the power at the outlet, which could already be full of EMI/RFI. I assume I am missing something...
check the link in post #2 i gave, then read up more over here:
http://www.geocities.com/jonrisch/ac-cords.htm
WorkingAtHome said:I can't think of any benefits
Neither can I.
Mind you I did own a pet rock once so maybe I'm not the person to ask.
Cal
Nor can i. All the explanations i've heard don't hold much water . RF filtering? Gimme a break, why is then so difficult to create an RF filter out of discrete components which sounds the same as an excellent power cord?
So, as with so many other things that really make a difference (at least to many of us) in audio i am happy to enjoy the benefits without understanding them. Dumb attitude, i know, but it works.
Isn't it amazing that, after all those hundreds of kilometres of 'bad' cable carrying power to our houses, a single metre of 'audiophile' cable can make an audible difference?
real said:Isn't it amazing that, after all those hundreds of kilometres of 'bad' cable carrying power to our houses, a single metre of 'audiophile' cable can make an audible difference?
Isn't it amazing that capacitor put in a signal path makes an audible difference as well?
The signal path is a bit different to a line that goes through a fairly lossy magnetic coupling then is integrated, then the PSRR of the amp weeds some more out, though 😉
WorkingAtHome said:I assume I am missing something...
A 800VA transformer with primary connected but secondary not connected consumes about 400VA of reactive power. The corresponding current generates a rather strong low frequency electromagnetic field (H field). No mains filter can filter that.
So, mains cable geometry counts for sure. One can find enough info in EMC books to evaluate "how much".
A transformer has also inter-winding capacitance (it can be measured approximatively with a multimeter). At least this provides a path for high frequency currents (example: diode switch-off noise if no snubber or capacitor across rectifier bridge). This HF current must return to its emitter else it won't go anywhere. For exemple, the current loop may pass through mains, another audio device, and interconnects. This is quite a huge loop, so it's quite susceptible to be noisy. Past a frequency, any cable reacts as a transmission line (with +/- losses). This impacts the "how much sensitivity vs/frequency".
So, HF behavior of mains and interconnect cables may count. And it is maybe the reason why a "fantastic" cable used by somebody can sound "dull" on somebody's else equipment.
Yoghourt
P.S. not talking about HF, a mains cable gives a replica of *voltages*, not *power*. And electromagnetic compatibility is most of time a matter of *current* (so say my books, burr-brown, analog device, etc...).
I forgot to mention something: in my little experience, playing with room accoustics (moving furnitures or carpet, changing curtains, adding/moving a small table, etc) has -by far- a greater impact than changing a power cable. And also a higher WAF score 😉
- General Interest
- Everything Else
- Power cables - advise
