hello
I have a problem I would like to include in the volume control a strip of LED indicators
I have to take a potentiometer with 3 outputs, or can I use a stereo one ?
Thanks to all
Thanks to all
Do you want the LEDs to simply tell you where the knob is pointed or do you want them to indicate the signal level?
I do think he means to indicate pot position.Do you want the LEDs to simply tell you where the knob is pointed or do you want them to indicate the signal level?
Riboli, you may think to combine two pots linking shafts instead of one dedicated ( maybe one stereo of good quality and one poor for led strips ? )
Never tried but it could works !
I want to indicate the position.
My idea was to use a pot with 3 outputs, 2 for audio and one for the position but it's hard for me to find it.
then I thought about using stereo potentiometer for volume and also for the position by entering an offset to the signal of +5 V and using two filters to send the audio signals (to the amplifier) and continues for the position (to the uC ) .. .
you think it will work or is a bad idea?
thanks roberto
thanks roberto
A 3 section pot might be hard to find,perhaps a 4 section pot would be easier? Maybe a second pot linked mechanically,
Use a LM391x IC,then you can choose between bar or dot mode.
It's a bad idea to pass DC through a pot that's carrying audio... it makes them very noisy as you turn them.
No easy way... you could mix a low distortion HF signal (100khz say) with the audio and use a notch filter to recover the HF and then fectify and use that to drive a level indicator.
I understand... I think I will use a pot with 4 outputs and the LM3914 IC or
I found this component PGA2311PA Datasheet - +/-5V Stereo Audio Volume Control PGA2311PA so in the future will also insert a remote control
thanks!
thanks!
Exactly as i suggested.Maybe a second pot linked mechanically,
I think that the main advantage is to use a very good pot for analog volume and a poor ( read cheap ) for the visualization function.
Dunno about quality of double stereo pots ( and costs )
Riboli, I also thought to do a thing as you want to do, in my case mechanical link is a must cause i use a stepped attenuator instead of pot 🙂
- Design & Build
- Construction Tips
- potentiometer and led
