Pot Mounting Bracker
Do you know where I can order online in the US those 90 deg. metal brackets to mount pots. The one used with the pot shaft extension.
I went to the local hardware store, they have those 90 deg. brackets but the metal is so thick and has holes pre drilled.
would Home Depot have something?
Home depot, Lowes, or any good local hardware store will have lengths (usually 4ft) of 1", 1.5", and 2" angle aluminum or steel. Cut it on a bandsaw, with a jig saw, or a hand saw down to the length you need (probably 1 or 2") and drill the holes you require.
